When using a NM KO plug in a metal box how far does it stick into the box? This is a question I could not come up with an answer from the NEC. 110.12A describes the opposite of what Im looking for. Any help would be appreciated!!
I don't think most of the replies have understood the question.
Where do we come up with the question addressing NM cable? All it says is a NM KO plug? There are non metallic plugs that snap into standard raceway size holes, and are typically designed and probably listed for sealing holes in metallic enclosures. If it is listed for the purpose why should there even be any question of this nature?
A metal plug in a nonmetallic box is an entirely different issue.
If OP has accurate recollection of the question - it is a totally unacceptable question for exam purposes.
