Grouch
- New York, NY
I believe Bob (iwire) is referring to the passages in the Certifications Directory from UL, commonly known as the White Book. "Power strips" are termed "Relocatable Power Taps". This is part of the 2015 / 16 section for them:
Al,
I think this statement from the White Book pretty much nails it (from the excerpt you sent)...
"Relocatable power taps are not intended to be permanently secured to building structures, tables, work benches or similar structures, nor are they intended to be used as a substitute for fixed wiring. The cords of relocatable power taps are not intended to be routed through walls, windows, ceilings, floors or similar openings of buildings."
This to me is saying you can't use power strips (relocatable power taps) at desks. The intent of the client is to use them as permanent fixtures, which is against what the White Book is saying.
