I would go with solar if it is possible. Did you say what the load is?
If solar wont work can you use Chaper 9 Table 8 note2 to calculate a multiplier for K to use the actual soil temp at 2 Ft or whatever your depth is?
My guess is you would have 18° C or a k= 10.5 for copper or 17.2 for aluminum.
If your load is around 1000VA for eaxmple
#4 AL USE/XHHW-2 Aluminum @6500 FT with a K =17.2 would be around 468V
For medium sized loads like 7-12kw you could use a 1000V nominal system and PV wire:
http://hvac.southwire.com/wp-conten...TOVOLTAIC-WIRE-1000-VOLT-TYPE-RPVU-–-BLACK.pdf
I am looking into that for water pumping on a large farm now.
