kwired
Electron manager
- NE Nebraska
I assume no attic access, if there is use all thread and crawl in there to put a nut on the back side of the framing member you are trying to use for support.
one of my supply houses has lag tips with threaded rod on the other end.
I didn't even think they had a real use, until this thread. I don't know how you install them tho, since there is nothing to turn, its just a lag tip and a threaded rod tip
I'd connect the rod to the tip, leave the rod 6" long, or so, drill a large enough first hole for the tip and coupling to get through, tap the end of the rod with a hammer to set the tip, and use a pipe wrench, or even a vice grip to grab and turn the end of the rod. Once set, I'd cut the rod to length.I don't know how you install them tho, since there is nothing to turn, its just a lag tip and a threaded rod tip
... I don't know how you install them tho, since there is nothing to turn, its just a lag tip and a threaded rod tip
Put the rod coupling on the stud and a hex head bolt in the other end of the rod coupling. Use the bolt head to turn.They fit into a threaded rod coupling
Gettin' 'em out is a little harder... but try two hex nuts jammed together and use the first one on to turn CCW. If that fails, add a third nut and try again.
A cap nut would work fine for screwing the studs in. Only problem is that the nut may get too tight to remove it without spinning out the stud, and usually we don't want to grip the threaded part of the stud to remove the nut. With a coupling and hex head bolt, one can grip the coupling to remove the bolt, and the rod coupling is going to be used in the final assembly anyway. Perhaps the better alternative in the OP case, is to use the eye bolt to turn the stud in and its done.the guy at the hardware store said to use a cap nut to drive them, but I think I like the two hex nuts jammed tite (and the drive nut in a coupler) as a better solution. I think the coupler nut would just thread all the way on and I guess it would finally hit the wood threads and then it could turn it.
POCOs here won't even allow screw-in's any more.
Call me crazy, but why can't you lower the thing 6 inches and drill a lag eye into a stud? The hooks got to be below the head anyway. And you'd get more bite in 3 1/2" of stud than through an 1 1/2" of rafter. JCP&L has run them though the siding here and a strong wind can pull em out. LIPA really that crazy about the way you install the hook?
