Fan Airflow vs Power Consuption
Nope.
It's general.
If you think it's incorrect, then I once again invite you to post what you believe to be the correct equation.
Bes, I'm going to step away from the discussion for a few hours to do something with my son. In the mean time, I would invite you (actually beg you) to take a closer look at what you are saying here. I am throwing away the posting that I started to write here in order to give you some more time to think about this.
I am not challenging your equation, but I am challenging how you are using it as it relates to this THREAD. As you think about this discussion, please re-read the OP's comments, and also understand that I am NOT the same person that earlier questioned a statement you made.
Please pause and reread what has been written here. Please make sure that you are not arguing a topic that is not the same as what I (personally) have stated.
If you do this and still believe that we are arguing the same thing, then I will take the time to engage you. I will be back in a couple of hours.
You disputed its general validity.
If you think you have a better equation then please post it.
Hope what you are going to to do with your son goes well for both.
I'm having a good weekend with my son, so I have decided that I am not going to bother trying to argue with you and spoil it. However, I will at least point out that I have repeatedly mentioned the "g" (acceleration of gravity) term that you have yet to address.
If you want to discuss this without blowing off that rather critical topic, then I am open to it. However, I am not going to spoil a good weekend butting heads otherwise.
.... All you have to do to see it is correct is to take the pump that your equation is discussing and block the outlet and see how high the amperage rises. It will go through the roof.
Jumping in here to ask- If the pump (or fan, since that is what the OP was asking) is stopped from doing any work, other than keeping its moving parts moving, why do the amps go through the roof?
You need mass to calculate power.
And, yet again, if the think the formula is invalid, please post what you think is right.
The "system" isn't doing work, but that doesn't mean the "motor" isn't doing work. That is the problem that is being overlooked in many of the original responses.
If you would like an analogy, consider a belt-driven compressor. If the compressor stalls, then no work is being performed by the compressor. However, we all know that the motor driving the compressor will still expend power just for the slipping belt.
bpk said:
This maybe more of an engineering / physics question but when a fan such as ID fan or squirrel cage is restricted on the airflow inlet side, such as louvers or dirty filters, does the fan draw less power. If so what about being restricted on the output side ? Thanks in advance
I happen to have this squirrel cage fan in my basement.
With it operating as unrestricted as possible at full speed. 4.8 amps
With it operating with only the the inlet blocked at full speed 3.8 amps
With it operating with only the outlet blocked at full speed 3.7 amps
I have to assume you have switched the topic to positive displacement pumps and not centrifugal blowers.
OK, if you say so. But why do you need WEIGHT?
To get mass, of course.
Let me give you a very simple statement to demonstrate the difference between weight and mass.
A force of one newton acting on a mass of one kilogram fives it an acceleration of one metre per second.
That force would give that 1kg mass the same acceleration here on earth or on the moon. But the weight would be much less on the moon.
Now, instead of disputing the formula, why don't you simply provide the one you believe to be correct.
Enjoy your day with your sun.
No. The question stands. Why does your equation need a weight?
