winnie
- Springfield, MA, USA
- Electric motor research
I would like to fasten strut channel directly to a surface using 1/2" expanding sleeve anchor studs.
The problem that I have is that the nuts that go on to the ends of the studs are 3/4" across the flats, and a socket for these nuts will not fit between the 'lips' of the strut.
Can anyone point me to a tool designed to tighten nuts 'inside' a strut channel? I am imagining something like a cross between a socket and an open end wrench, that could be slid on from the side.
Currently my best solution is to use long 'coupling nuts' that extend all the way out of the channel. But it seems to me that there should be a way to grab onto a normal nut.
Thanks
Jon
Thanks
Jon
