winnie
- Springfield, MA, USA
- Electric motor research
Jon,
I'm not familiar with the term 'series rated' Could you shed some light?
The idea is that the _combination_ of two OCPD in series gets rated for higher short circuit current than the individual devices.
The most common situation is a panel where the main OCPD has a higher rating than the branch OCPD, but the 'series combination' can handle the higher fault current.
The devices have to actually be tested and demonstrate proper protection against the short circuit current, and you lose things like coordination; the main might open before the branch breaker. But it lets you use less expensive hardware.
-Jon
