- Wisconsin
- PE (Retired) - Power Systems
If the first house experienced a sufficiently large fault, L-L or L-G, it is theoretically possible that the output voltage of a shared transformer could be pulled down to a voltage low enough to cause a generator to start. Failures in the backup systems are not uncommon and are often only found during actual utility failures rather than simple generator start tests.
