- San Francisco Bay Area, CA, USA
- Electrical Engineer
If it's a tang, two on top back-to-back, two on bottom back-to-back, long bolt.well ..lots of thoughts on compression lugs .
can anybody suggest a solution from any manufacturer to stack four compression lugs ( single hole) to one terminal ?
If it's a stud, make a tang out of bus bar to go on it.
One hole is bad for rotation, especially when you have a lot of connections like that, be careful. If it is a stud, I'd make a two hole tang and use two hole lugs, bolt them all together, then mount the tang to the stud. You likely would have to make it stand off of the bottom with a spacer, or put an offset bend in the tang if the stud is too short.
You have to use your creativity when faced with a challenge.
