What about a garage that is insulated and sheet rocked, walls and ceiling? Would you consider this finished--should it have an outlet every 12 feet? Thanks, TimOriginally posted by jwelectric:
I too agree with the wisdom of Sam and Charlie on the call of is this finished. Having been in this situation before with basements and rooms over garages I have found that the one question that the Inspector always asks was; ?Is this area heated or air conditioned??
If the floor is carpeted, are your bare feet touching the concrete or the carpet? It's not like a normal installation would be the put plywood over the concrete than put carpet down.Originally posted by jimwalker:
Well thats every outlet in most homes here unless we think carpet will make a differance.I agree its a good idea but dont see it likely to happen because of the cost
Not if it is a garage. One receptacle is all that you need.Originally posted by timhood:
I see in Article 210.52 (A) (1) that the distance between receptacles in a dwelling is 6'. Where do I find reference to the 12' rule?What about a garage that is insulated and sheet rocked, walls and ceiling? Would you consider this finished-- should it have an outlet every 12 feet?
This would explain why some houses have a gazillion receptacles spaced only 6 feet apart.Originally posted by 1793:
Thanks
Norb
