It is not true that theoretically the voltage ratio should be 1:1 for my definition of a transformer. My definition of a transformer is the magnetic coupling of two or more current paths. My definition does not require good magnetic coupling.What was your primary to secondary voltage ratio. Theoretically should have been 1:1, if both reels of wire were the same thing, but just curious how close that may have come out.
What about a fan regulator as a variac?A "power electronics device", as in triac or SCR based? That would introduce a lot of harmonics which would overly complicate the "simple" transformer experiment.
A fan regulator (speed control?) is not a linear, sine wave output, device.What about a fan regulator as a variac?
Yes, it may be a stretch to assume that those in the err electrical trade has any knowledge in regard to the basics of electricity and the basic skills to be able to use basic tools. This is one reason why the OP transformer failed for the most part because of the core. He has the right idea regarding the windings but without an acceptable core design transformer coupling is slim to none. Even a basic relay, contactor, etc with an AC coil will have a laminated iron core. You would be more successful energizing an AC coill with DC that trying to energize a DC coil build with a solid core with AC....file the cut surfaces smooth such that they joint back together flush...
If you are assuming the OP is a master tool and die maker to be able to file like that*, might as well tell OP how to mix Zn, Mn, and Fe powders and how to bake it to make ferrite, then he can run at 10s of kHz. <G>
* or has a platen belt sander, or ....
0r, leave the air gap there and make a flyback transformer and use a couple of IGBTs and PWM drive....., etc..
or, while we are going way out, tell OP to go to the farm supply store and get a big 50 pound coil of 19 gauge vinyl coated fence tension wire. Then it only takes threading a few dozen turns thru the spool to make a pretty decent 60 Hz transformer.
Sometimes people blow instead of suck, just depends if they are inhaling or exhaling at that momentWow, everybody sucks except for you.
Wonderful. Nice response.
My response was to that of junkhound who may have been sarcastic in his opening sentence but it did made sense though.
My previous assignment was with a custom dry type transformer. I have to apologize for my being amused with the replys to the OP's question when it is obviuou that his design lacks an acceptable core.
I have a couple custom 1500kva core and coil that was shipped to Australia for installation in a nitrogen infused totally enclosed no ventilated enclosure, 4 padmounted transformers ieach in 6'x6' enclosures at the Guam Intl AP, a transformer to power the chiller for the George Washington University auditorium, a custom designed encapsulated liquid cooled transformer with a 1/4" welded steel enclosuremounted on a underground rail car custom encapsulated transformer on an oil rig off the coast on East Africa, a transformer that powers the X- Band radar ft or Israel's mistake defense, a number a current limiting sir core reactors consisting of 3 individual 10'x10'x10' enclosures.
I also observed my winder disassembling a transformer to do an autopsy for a cause of failure.
These are just a few of the projects as I can recall where I had to work with my customer and my engineers to design and build a transformer for their project.
It may be that what I find to be obvious is not so obvious to others when it come to transformer basics.
There is an error that spell correct did its own thing on. It was suppose to be " Israel's missile defense ."
And "sir core reactors"??
