fixed elec. space heating
kd5ufw
is the air handling unit portion of an A/C or heat pump system with resistive heat strips considered "fixed electric space heating" ? if so, where might I find that defined in the NEC?
I would not consider the air handling unit, "fixed space heating" , but a
disconnect for the motor and the heat may be the same one.
424.19 NEC 2005
Really? What would you consider a central electric forced air furnace? That is basically what this is.
