Flimsy EMT drops from 20ft ceilings
petersonra
Northern illinois
engineer
Im making several EMT drops from 20ft ceilings. I've tried Unistrut on the bottom 10ft, Rigid, Unitstrut and Rigid, Hanging from Allthread from lower elevations. Nothing really suites me, it still seems flimsy. What's a sturdy method? These are 30amp and below in size, and both 480v or 120v.
Im also thinking about cord drops, Kellum grips, aircraft cable, and cord connectors///:smile:
Use unistrut and run the wires inside it. it is listed as a raceway.
iwire
Massachusetts
i take it it would have to be the solid type right?
Yes solid.
Here is a typical application of strut raceway
Article 384 covers the rules for strut raceway.
Mule
Oklahoma
Ive already fired off a email to my client, suggesting this method and since they always drop air in the same locations, via hard pipe, they could run PEC tubing down the opposite side of the "back to back" strut into a 90deg bulkhead fitting for the air chuck.......SLICK....:D Thanks for the great idea, and I gave credit in the email to this great forum at "MIKEHOLT.com" !!
iwire
Massachusetts
Thanks, I do 98% of my business with CED American Electric, and I dont know what brand of strut the've been selling me.....I just use it...:smile:
I understand but I am pretty sure B-Line and others make similar configurations. :smile:
Fulthrotl
~Autocorrect is My Worst Enema.~
yeah, the other side can be used for cat 5, air, whatever.
when i've used it this way, a 4 bolt flange on the bottom works well,
and some inspectors will have a problem with welding raceways, if
you are gonna butt them togeather, make sure you aren't gonna have
a problem with your inspector.
covers are 10'... i've never seen 20' ones, and putting them on and off
would be a pain.
used to use single strut for industrial lighting way back when, and you
could get it with 1/2" ko's in the back... just knock out one and hang
your lighting with a chase nipple into the strut, and 1/4"-20's and
fender washers for support, and all the wire goes in the strut.
and no drilling or pulling holes. it is a really clean install.
hillbilly1
North Georgia mountains
Owner/electrical contractor
I don't know if you have forklift traffic or the like, but I have used 3/4 emt flattened at both ends, run at a 45 degree or less angle to the conduit drop with a minerallac strap on the conduit with the other end bolted to the bar joist. I use two 90 degrees apart. Works well with larger conduits, haven't tried it smaller conduits. Economical and sturdy.
