Normally, the impedance to neutral shown in your diagram is very low compared to the load impedance. The loads in this case are not a voltage divider; the same current does not go through each load. Each load is across 1/2 of the secondary winding.realolman said:It took me a while to get this post accomplished... crossman, I don't understand your second hypothesis. Why would one phase be subtantially higher than the other with respect to the neutral bar.
The connected lods acting as voltage dividers would do that according to their impedances, but I dont see the high impedance (bad / no connection ) of the neutral doing it.
If the neutral is open (impedance very high), then the loads will act as a voltage divider because the same current goes through both loads. A heavy load (low impedance) on one leg will have a low voltage drop and a light load (high impedance) on the other leg will have a high voltage drop from the same current going through both loads.
