I have a project where the electrical contractor installed a floor outlet in front of a rolling full height window. The engineering plans show the floor outlet at the non movable portion of the window. However, the architect flipped the window configuration in the field which resulted in the floor outlet now residing approximately 18 inches away from the movable window partition :blink:. The movable window partition opens to a Juliet balcony (i.e.: can not have human access and is just for show). The wall spacing still woks for the other outlets (less than 6 feet). Are there any issues with this code wise that you can point to me that clearly shows that it is a violation? or can it be left as is.
