hurk27
- Portage, Indiana NEC: 2008
I guess this stresses the importance of 300.50(F).
My guess is the conduits were not sealed, but I wonder if ductseal would have been enough to stop the vapors (I don't know what kind of pressure was developed).
300.5 is for where there is a change of temperature in a raceway run, such as at the service where a conduit is between the meter can and panel that is inside in a heated or cooled environment, in the OP case where the conduit and panels or junction boxes are all out side 300.5 would not have applied, and yes you would be correct, the sealing is only to slow down the transfer of air between the two points not to totally prevent it, all it is supposed to do is prevent moisture build up as the air changes temperature.
