So you get your bulbs setup and it works great...Yes from what I have read they must be kept wet
Do you go enough to keep water from evaporating out off the pump?
Yes I am up there frequently. Some people in area keep their places heated to 50, I don't want to waste energy like thatSo you get your bulbs setup and it works great...
From what little I've read, RV antifreeze is good for the pump seals. But IMHO flashlight is good to be concerned about this because it isn't a no-brainer.
You _don't_ want to drain out the pump; if the seals dry out then they shrink and crack, and then they _will_ leak.
-Jon
They'll last forever, but won't provide a significant amount of heat.... wire two in series ... they'll last forever.
Sure, install an air compressor, or haul one with you when you go on "vacation".... Put a compressed air fitting ...
But if you do pressurize the entire dishwasher then we want video.....(short of pressurizing the entire dishwasher ... which I enthusiastically do not recommend)
They do have a vent typically in top wall, as well as in the door - drying cycle needs inlet and outlet for air flow drying fan typically in line with the top wall vent. So you either going to need a massive air supply and send a big surge of air or find way to plug those vents.But if you do pressurize the entire dishwasher then we want video.....
OP's concern was to purge water from the drain pump and the lower portion of drain pipe. He already mentioned draining all the water supply lines. If DW supply line comes from above the DW then might want to turn it on and let it purge the water out of the low spots. If DW supply line comes from below the DW he probably already is eliminating water in the supply line, though there could still be small amount of water that gets left between the DW water valve and inlet to the "tub", so turning it on to allow that to drain out might still be good idea.Put a tee in the water line between the water shut off and the dishwasher inlet. Put a compressed air fitting on the branch of the tee with a valve between it and the tee. Put a little air pressure on it and run the dishwasher.
If you use an incandescent ligt bulb, but the extra long life ones. They are typically 130V, have an orange tinge, but can last quite a long time...
Because we're us. Why use a simple solution when there are myriad complicated ones for us to debate?![]()
Down side to that is you likely committed to washing every dish that ever needs washed from then on.Sounds like my wife. "Honey, I want a dishwasher".
But we have no place to put one.
"Can't you remove the cabinets next to the sink?"
But what will we do with everything that's in them? Know what? I can wash dishes faster than any machine, it costs nothing and we'll still have our cabinets.
Don't get me started on garbage disposals...
-Hal
Incandescent lamps (what used to be the good ones) are difficult to find anymore, not saying impossible but not stocked in all the places that once carried them.My first thought was 116W traffic signal bulbs, which are usually rated at 8000 hours. However, the quality is getting worse. The bulbs we're using for tower obstruction lights are having a higher premature failure rate...usually the bulb seal fails, which makes pretty smoke patterns in the glass.![]()
Hal, I was concerned about pump seals, maybe not an issue?
Larry, when I first started as an electrician in mid eighties, an old timer showed me how to make
a tester from 2 pigtail bulbs in series. Glowed dim, 120, glowed bright, 240.
But I hadn't considered bulb life in that setup
If incandescent bulb resistance were constant, two in series would provide half the heat of a single bulb. Since I understand the resistance significantly increases with operating temperature, two in series would provide somewhat more than half the heat of a single bulb.They'll last forever, but won't provide a significant amount of heat.
