jetlag
- Eatonton, Georgia
Hi , I am having trouble finding out the proper way to install the low voltage wiring for garage door openers . Right now I just need to know what wires are needed in the floor trusses above the doors before the insulation and drywall covers them up . It is my own house and I didn't want to run the wires exposed under the ceiling . I have the 120 v recepts roughed in for the door openers in the ceiling . OK , there will be 2 garage door openers . One on a 8x8 and another on a 16x8 . I want to be able to open these with a remote control from the outside or the inside. I also want a push button control for each one on the inside where I come out from the basement into the garage , and that wall is on the opposite end of garage from the garage doors . I have heard I will need a control wire from the motor location down each side of both doors . So that is 4 wires in the ceiling and also a wire from each push button on the wall up to the ceiling and over to the motor locations . Would I also need push buttons on the inside by the door that enters the garage in case I dont have the remote or it doesnt work ? Or would I just have to walk to the buttons on the opposite wall . Is there any other wires that need to be installed now in the ceiling ? Do the censors go on the wall on both sides of the doors ? do they go on the inside or outside ? Also what is the guage and numbers of the conductors for the bell wire
