highkvoltage
Heres the situation.
1. Garage detached from house and feed from the panel located in the house.
2.4 conductor feeder installed. 2 ungrounded, 1 grounded, 1 equipment gound.
Is this concidered a serperate service?
Does this require a ground rod at the garage?
If there are more than 6 circuits does the panel require a main breaker?
The inspector and I disagree on all 3 areas. I feel it is not a new service, since I installed 4 conductors it does not need a ground rod and it does not require a main breaker because there is one at the house panel.
The inspector won't move and claims he is using the 2002 NEC.
