I have a gas station owner that intends to replace the existing building. The new building will be behind the existing building, which will become parking/sidewalk area. The undergrounds for the pumps, dispensers, etc must be extended to the panel in the new building. Since the 8 or so conduits for underground wiring are mostly under 8 inches of concrete and sealed (hard to replace the existing wires), what is the best way to splice into each of the existing conduits and extend to the new location? Cut conduits and install compression fitting with conduit body on each? What is best way to cut conduit without cutting wires? Thanks.
