Two to six service disconnects shall be permitted for each service permitted by
230.2 or for each set of service-entrance conductors permitted by
230.40, Exception No. 1, 3, 4, or 5. The two to six service disconnecting means shall be permitted to consist of a combination of any of the following:
- (1)
Separate enclosures with a main service disconnecting means in each enclosure
- (2)
Panelboards with a main service disconnecting means in each panelboard enclosure
- (3)
Switchboard(s) where there is only one service disconnect in each separate vertical section where there are barriers separating each vertical section
- (4)
Service disconnects in switchgear or metering centers where each disconnect is located in a separate compartment
