kwired
Electron manager
- NE Nebraska
- EC
That is ridiculous, NEC states what qualifies for a grounding elecrode and tells you if it is present you must use it. If no naturally existing electrodes are present then it tells you you need to install at least one made electrode. Only naturally existing electrode that needs supplementing is the water pipe electrode, otherwise I have done many new buildings that have just a CEE and no other electrodes.This is true. I dont know if its the same for every ec here but grounding is basically pick 2 out of 3 cw bldg steel and ground rod. You choose.
