ceb58
- Raeford, NC
A disconnect will need to be installed per 225.32[/COLOR]
I understand the need for a disconnect, my question is why 225.32 is in section II. More than One Building or Other Structure. If you were looking up the need for a disconnect how would you know to look here? This section implies that the disconnecting requirements is for more than one building or other structure.![]()
Art. 225 is for outside circutes and feeders. The generator would be considered "other structure". And coming from the generator would be the outside feeders. Look at the scope in 225.1 But lets say you are looking for info. on a install. You start, in this case, with Art. 702. Then you see in 702.11 Outdoor generator sets........................................ The disco. shall meet the requirements of 225.36. Then you go to 225.36 it tells you Suitable for service equipment. It tells you that that disco specified in 225.31 shall be suitable for use as service equipment. Then you look at 225.31 which will lead you to 225.32 for the location of the disco.
It all comes back to the fact that the feeders are installed outside and would fall under 225.
