GAK
- Western South Dakota
- EC
Hello Friends,
I live in a small development of five houses with a shared well. The well only produces about five gallons a minute so we have it fill a 12,000 gallon cistern and then jet pumps to pressurize.
Now we are talking about adding a standby generator to keep things moving when power is out.
Installing a generac and transfer switch would be no problem at all, and I have installed a few. However I would like to have the generator controlled by the demand for water so it isn’t running continuously with no call for water and no load so it isn’t just sitting there running wasting propane.
To do this I can run a switch loop through a pressure switch to control the jet pump, and use a float for control of the well pump. Also I would like to maybe set up a minimum run time so as not to short cycle the generator if a couple people are showering or something.
Another option could be to have the generator run for like 15 minutes every hour then off for 45 minutes on for 15 off for 45 etc.
Is any of this possible with the generac transfer switch or some other brand? Does anybody have a better idea how to do this?
