RonJon
New member
- dallas, pa, usa
Is it safe? Recently purchased a home with a 5500w generator system. The generator has a heavy duty, four prong generator plug from generator to a receptacle which is wired to a 30amp breaker in the main panel. The wire has a red and black wired to the double pole, 30amp breaker. The white wire and bare ground are wired to the panel's ground strip. The generator breaker is normally in the 'off' position. The instructions at the main panel are to throw the 200 amp main breaker 'off' when its appropriate to use the generator and turn off certain breakers like the A/C unit, swimming pool motor, basement sub-panel, etc. Then start the generator and turn 'on' the 30amp breaker for the generator in the main panel. Is this a safe hook-up and is the procedure accurate?
