Generator Interlock
mkgrady
Massachusetts
I have a customer that wants a portable generator connection. I typically install a gen breaker in the main panel and interlock it with the main breaker. In this case he does not have a main in the panel. It is out at the meter. There isn't enough room in the panel to add a main.
I'm hoping to install a breaker between the outside main and the inside panel. I'm picturing a 3R enclosure main lug with a 100 amp and a 30 amp breaker and interlock. I'm not sure I will find a four space 100 amp panel that can accommodate an interlock. Any ideas?
hillbilly1
North Georgia mountains
Owner/electrical contractor
A lot of manufactures use the same can for the mlo and breaker type load centers, if the panel is new enough, I just buy the main breaker version and swap out the guts and the cover. Then an interlock kit can be used inside. Just done that last year with a Siemens loadcenter.
Dennis Alwon
Chapel Hill, NC
Retired Electrical Contractor
Why aren't you going to use a main breaker panel? They make interlocks for them and some manufacturers make a panel designed with an interlock built in.
mkgrady
Massachusetts
The panel inside does not have a main breaker and there is no room to add one. The main breaker for the service is a combo meter socket/main breaker so there is no place to put a gen breaker and interlock. I plan to put a mlo panel outside and interlock it with a gen breaker. I just can’t picture a 3R four circuit panel that will accept an interlock.
drcampbell
The Motor City, Michigan USA
Registered Professional Engineer
Maybe a meter, main and breakers in one box?
(Eaton #MBT48B200BTS)
mkgrady
Massachusetts
We usually end up doing a Sq D HOM816M200FTRB with a gen interlock in a situation like this.
Sent from my SM-T820 using Tapatalk
Thanks. That looks like it would work. I don’t need the 200 amp rating but it can’t hurt. I was thinking something more compact but it doesn’t look like I will find anything
jim dungar
Wisconsin
PE (Retired) - Power Systems
The QO line has a QO1DM10030TRBR: 100A main interlocked with a 30A gen breaker, subfeed lugs, and space for 4 branches, probably still bigger than you need.
Eddie702
Licensed Electrician
Western Massachusetts
I have done it with older panels with no interlock available by installing a sub panel with a main and an interlock. Move the 'emergency circuits into the new sub panel
GerryB
How about just the old style 100 amp manuel generator bypass switch. Did one years ago for a friend, I would say you can still get them but I don't know. The 200 amp is pricey but the 100 amp is not. (just looked online, saw one for $153.00, not available for 4 weeks because of the storm on the east coast.)
Todd0x1
CA
I was just going to post this after confirming it comes with the 100A main, the datasheet isn't 100% clear but sqd confirms it in a faq, but you beat me to it.
This is probably the most cost effective option as the whole thing is only around $100 and includes both breakers.
Datasheet: https://www.se.com/us/en/product/download-pdf/QO1DM10030TRBR
LarryFine
Henrico County, VA
$170. A little more than the square D panel
Coulda saved you about $100. Above SqD interlock, two breakers, and this or similar:
mkgrady
Massachusetts
Yes $100 is nothing to sneeze at but I avoid square D because my local supplier charges crazy prices and I’m not sure what I can find at big box stores for interlock hardware. I once paid about $200 for a panel that Big Box sold for $80.
