Ed MacLaren
Re: Generator Neutrals
I see a series circuit, from Point A, in the following order, to Point B.
Through the GFCI, along the black wire, through the load, through the (green) EGC to the generator frame, into the earth, through the earth to the victim's feet, through the victim's body, through the load device enclosure, and through the (gray) neutral back to GFCI and the generator winding.
Keep in mind that the EGC and neutral have been mistakenly interchanged in the load device, as described in the article.
If you wish, substitute a wet concrete floor for the earth.
I changed the diagram a bit to clarify the current path.
Ed
P.S. I type real slow.
[ January 18, 2005, 06:26 PM: Message edited by: Ed MacLaren ]
The white and green are not directly connected to each other.I don't see a circuit between the white and the green
Ed
