I think you could use some help in understanding the terminology. The word "breaker" applies to the thing in the panel; it is never used in connection with a receptacle.rwi said:. . . but if the gfci receptical is itself a breaker why does it trip a second breaker (in panel)?
Sorry, Charlie, but that does not conform with my experience. The easy sign of a GFCI is the test button on the breaker. The only double-wide breaker with a single handle I've seen is a QO 2-pole.charlie b said:. . . it is generally obvious enough because it is twice as wide as a normal breaker, even though it has only one switch handle.
