steelbuster
- mn
I live where block heaters are a way of life. It's -35F and 20 knots today. So I should have an informed opinion.
GFIC receptacles are too flimsy, they breakup pretty easily in the cold. GFCI breakers feeding Federal Spec receptacles are a lot more robust (reasd less maintenance).
Doesn't matter if you use GFCI receptacles or breakers. the only good way to insure the circuit is on is to use lighted cord drops, or equip the trucks with a lighted plug.
cf
If all 40 receps are going to be on one circuit and you use a GFCI breaker, one bad heater means 40 dead trucks in the morning.
