zbang
- Roughly 5346 miles from Earls Court
Adding a D-Y transformer won't help (as much) if the ones supplying the delta aren't a similar size; often the one supplying the high leg is significantly smaller than the other. It'll also add a minor amount of waste load. And the high leg isn't useless if you have 3-phase equipment, that's why it's there.
Better to find the cause of the trips. Checked all the neutrals yet?
