#1. If an electric drill with a metal casing is powered by a GFCI receptacle will the GFCI still trip if the ground wire pin in the cord is cut?
#2. If an electric drill with a metal casing is powered by a GFCI receptacle will the GFCI still trip if the ground wire pin in the cord is cut AND polarity is reversed?
