Electriceel
New member
- Iowa
When using an ungrounded electrical tool, are you required to use a drop cord with a built in GFCI?
NEC 590.6 would require GFCI protection for receptacles used as part of a temporary installation for construction, etc.
In the end everyone's safety is their own responsibility. One should be using some sort of GFCI doing any power cord work. I use one around the house, I have portable ones in the truck.
Here is what OSHA has to say about it!
Welcome to the Forum!
But allows the use of portable GFCI devices and doesn't require permanently installed GFCI devices.That applies to construction sites.
Enough of the barbeque stories already!Yes but the op was not necessarily talking about a temp installation. I am thinking he goes to a job site and needs power to grill a hole and there is no gfci available.
This still would be covered under 590.6 specifically (A)(2) which would require some type of GFCI protection even it were of the portable type.
That is correct. And OSHA does back that up in it's own way, so even if you are not familiar with NEC you still have other references that make you use a portable GFCI.As I read that if I came to your home I would need a GFCI protected cord to use a receptacle in one of your bedrooms.
Anybody still have one of the Yankee brand long spiral screwdrivers?
Tapatalk!
Tapatalk!
Tapatalk!
