In a residential setting, the bathroom outlets must be fed with a 20 A circuit. And according to the NEC (I can't think of the number) this "can have no other outlets". But, the exception says that if the circuit serves only one bathroom, the circuit can supply other outlets in that bathroom. Isn't this correct?
So, does this mean that a 20 A circuit must be pulled to supply ONLY the receptacles in that one bathroom? Or, as some that I work with tell me, does it mean that this same circuit may supply the lights in that bathroom as well? Say for instance I have a bathroom that has a vanity sconce light, a recessed can, and a bath fan, and two receptacles adjacent to the vanity. Is this one 20 A circuit to be used for only outlets or can feed the lighting also?
Second question, the phrase "no other outlets", means cannot be jumped from bath to bath supplying only the receptacles?
Third question: The outdoor receptacles, do they have to be on their own circuit as well? Or can they be fed from a circuit which has a light load on it and install GFCI receptacles? Would any of you others feed an outdoor outlet from a lighting circuit? A living room receptacle circuit which only has 4 or 5 receptacles on it? What are options or recommendations from others?
Thank you for any help.
