I need to replace some Kitchen outlets with GFIS. They are wired from outlet to outlet with a multiwire circuit.(12-3 Nm) Can I put a GFI in every outlet opening or will I have problems with nusience trippings since all the GFIs share the same neutral? Line and Load will not work. I can make all the outlets one circuit. The red wire would feed all the way through to the Microwave outlet. Or could I use a two pole GFI breaker in the panel?
Thanks
Thanks
