Only far enough to not be submerged in water.Originally posted by rustad:
how far from a sink does a gfi need to be?
Triphase you did miss something, read the question again.Originally posted by triphase:
On a serious note 210-8(A)(7) If it is within 6' Also, if it is a kitchen, then all receptacles serving counter tops must be gfci. I guess ....Or did I miss something here?
That is a vauge question..... In a kitchen a bath a laundry a wet bar where.Each has its own requirements.Also what cycle are you in that makes a difference in wet bars.Originally posted by rustad:
What if the enclosure is listed for submersion?Originally posted by iwire:
I would like to see the "In Use" cover for that application.Originally posted by ryan_618:
But that would only apply under the 2005. In the 2002, indoor wet locations didn't need an "in-use" cover.Originally posted by iwire:
how far from a sink does a gfi need to be?![]()
Okay, I'm convinced. Please post a picture of a code-compliant submerged receptacle.Originally posted by ryan_618:
You can even quote yourself.Originally posted by LarryFine:
Now, I'm starting to get crosseyed.![]()
Just how deep can these quotes go?![]()
