Gounding Screw
Re: Gounding Screw
Originally posted by romeo:
A grounding screw having a flat head with a hex head will provide a much better connection than a round head screw designed to hold a clamp, and anyone that disagrees to that is not trying to do the best work. Just my opinion
romeo
I disagree.
Re: Gounding Screw
Scott, :D
Anyway, I would only agree that there would be a problem if it were a flat head screw.
But wierdly, (cool word :cool: ) the code doesn't address that. :confused:
Re: Gounding Screw
Originally posted by physis:
By Jhr:
why not use a green screw in these boxes, cuts out a lot of hassling over is it a ground screw or not,
I don't see what's confusing about what the screw on the bottom of the box with an EGC on it is.
If I didn't have a green screw with me I sure wouldn't be coming back tommorow with one when I have this silver one here right now.
Now 5 or 6 people standing around this box with the silver screw for twenty minutes................. :)
Re: Gounding Screw
By Jhr:
That is assuming that there was a problem to begin with. :p
[ January 29, 2006, 11:20 AM: Message edited by: electricmanscott ]
Re: Gounding Screw
For the record, I do use the UL listed green screws ( ;) ) only because they don't protrude so far out of the back of a 4" square. But for old work boxes, octagons and other places where there is clearance behind the box, the clamp screws will do just fine. :cool: But when in doubt I bring a can of green paint with me just in case. :roll:
Re: Gounding Screw
You do?
Are they PL listed? (Peter's Laboratories) :D
There are no 'listed' grounding screws on the market.
Re: Gounding Screw
I know, did you see the winking dude? I just had to make light of this ridiculous notion of "UL listed" screws. :D
[ January 29, 2006, 12:26 PM: Message edited by: peter d ]
Re: Gounding Screw
Just making sure, I did not want any lurkers to think that UL listed grounding screws where available.
Re: Gounding Screw
Originally posted by Shockedby277v:
What color is the green ground screw??
A.) Black
B.) White
C.) Green
D.) Bare
On the outside or inside?
Under what type of lighting conditions?
See we can muddy up even a multiple choice question. :D
Re: Gounding Screw
My hair color is now grey,but I had a blonde moment. I want to repeat that I was referring to a oval head screw that would provide a better connection not a flat head screw. I still think that a screw designed to hold a box clamp does not have the surface equal to a grounding screw.
The truth is it is designed to hold a clamp not for grounding. The NEC does not prohibit it from being used for used for grounding and I accept it. However the NEC may have had a blonde moment when it was allowed. romeo
