Hello everyone.
I need help with an outlet problem. I'm living in an older home where I think most of the outlets are not grounded so I'm unable to properly use a surge protector. When testing the outlet with a two lead circuit tester the light come on when the two slots are tested. When I leave the red lead in the short slot and test the ground u shape the light only slightly lights up. So is it grounded? When I touch the screw that holds the plastic cover to the outlet the light again, only slightly turns on. Any help would be greatly appreciated.
