Bro8898
- Birmingham, AL
- Master Plumber
It almost seems as if the ep bonded “area” and ep bonded objects are like an extension of the hot conductor if or when it comes in contact with something that’s ep bonded. And exactly what you said, if you were a bird on a wire that’s the only thing you would be touching.A high voltage or any "hot" conductor making contact with the EP bonded items, or even earth will attempt to "flow" current back to the source.
This may or may not be related, but does he really need the faraday suit? I’m sure from a ppe standpoint yes, but if he’s completely isolated from the ground on the scaffold it would seem that no further protection would be necessary.EP bonding is why in the video even at 220kv the person was able to "bare hand" the live wire.
Also, what potential is the technician at when he standing on the scaffold? Is he at zero volts, or “not” zero volts? I understand that once he bonds himself to the live wire he is at 220k and when he’s in contact with the ground he’s at 0, but what about once he stands on the isolated scaffold?
Thanks
