If the sheet really was grounded, and the light on your night stand had a fault and some metal part was energized, you would get electrocuted. Then you would sleep really well after that.
I remember on ebay a few years ago seeing someone selling wood blocks with a ground wire attached to each block. A set of four was several hundred dollars. You would put them under the legs of your stereo system to ground it. The profit margin looked quite substantial.
