On the issue of ground rods a lighting poles, my theory is when lights were first put on poles, they were supplied from an system with no EGC, so a ground rod was added. This habit carried over to today but has taken on the lightning protection myth. I researched this for Mike Holt, and I never found direct evidence of a foundation being damaged by lighting. In this article
The author did high voltage impulse testing of various footings with rebar and found no damage
The conclusion was
The article is from Aug 1970. Its copy righted but if you want a copy you can get one from the IEEE
