Grouch
- New York, NY
I'm having trouble visualizing this section in the 2017 NEC: 250.64(D)(3); it describes connecting the GEC to a common location. My questions are as follows:
1) The GEC is connecting to the line side of the disconnecting means correct? It is NOT connecting to the grounded service conductor / neutral INSIDE the disconnecting means, but rather connecting to the GSC before it enters the disconnecting means?
2) What exactly do they mean by 'common location'? What if you have 2 disconnecting means, each one with a set of service entrance conductors tapping off an End Line box / demarcation point from the utility? where's the common location?
