I have a scenario ( residential) where the incoming copper water supply is almost 225’ per wire route from the service disconnect.
Is there a point when the distance of the wire run outweighs the effectiveness of dissipating the fault?
The entire length of the wire run is in the building interior . I t consists of traveling through wall space, attic space, crawl space and above a portion of dropped ceiling.
It is literally the furthest point from A to B.
There are currently 2 8’ driven rods at the service but the copper water is available just in no way convenient.
Does it need to be used if I can prove 25 ohms or less at the 2 driven rods?
