- Windsor, CO NEC: 2023
- Hospital Master Electrician
Cwolf, welcome to the forum.
That statement denotes a misunderstanding, so I would like to address it. Electricity is seeking any path back to it's source, not the path of least resistance to ground. If you drive ground rods, connect them to the pole, and leave the pole unbonded, then both the rods and people will be conducting current. Driving a rod does not cause the current to take solely that path. It will take every path.cwolf said:...anyone coming into contact with this pole would become the path of least resistance to ground.
Not unless several rods are driven about 4' deep, and then used as a picket fence.However, by unbonding the neutral from the pole and driving individual ground rods at each one, you have lessened the possibility of someone coming into contact with an energized pole.
