kbsparky
- Delmarva, USA
We have an upcoming project that will utilize about 10 wooden poles. Mounted at the top of these poles will be stadium lights for a ball field.
When dealing with 50 foot poles out in the middle of a field, they are the highest point around, and a target for lightning. Good grounding should minimize any risk of equipment damage.
I want to ensure that the light fixtures and associated mounting hardware have sufficient grounding -- in addition to any equipment grounding conductors present.
That being said, I propose to use what is commonly called "butt grounding" -- a coil of bare copper ground wire wrapped on the bottom of the poles, and/or a grounding plate attached to the bottom of the pole, with a #6 wire leading up the pole and attached to any steel structure present. Manufacturer's literature suggests that such grounding is superior to using driven ground rods adjacent to the pole.
What have been your experiences in grounding wooden poles?
