Treg the electrician
- lynnwood washington
- electrician
are you guys putting hard wired EV chargers on GFCI breakers?    Im talking level 2 chargers in residential..
			That should be corrected in the 2026 code. The word "in" in that section should have been "at" as the rule is only intended to apply to outside locations and not locations within the listed structures. This change was accepted in the first draft meeting, but of course subject to the actually ballot results and possible change in the second draft.EVSEs often provide ground fault protection, but not at a level that qualifies as a GFCI. A GFCI has a 4-6 ma trip threshold; EVSEs usually implement CCID20 which has a 20 ma trip threshold. So for the purposes NEC GFCI requirements, EVSE do not provide GFCI protection.
Article 625 (EVSEs) has a requirement for GFCI protection of a receptacle installed for an EVSE, but that would not apply to a hardwired EVSE.
In the 2020 NEC and later, 210.8(F) requires GFCI protection for all equipment installed outdoors at a dwelling unit on a 50A or smaller branch circuit. So that covers any outdoor EVSE rated 50A or less.
In the 2023 NEC, 210.8(F) was expanded to also cover "Garages that have floors located at or below grade level" as well as "Accessory buildings." That will require GFCI protection in many (most?) garages, again for units rated 50A or less.
Cheers, Wayne
The first sentence of 2023 NEC 210.8(F) says ""For dwellings, all outdoor outlets . . ."The word "in" in that section should have been "at" as the rule is only intended to apply to outside locations and not locations within the listed structures.
I've never seen an EVSE with GFCI as the NEC defines it. Again, most EVSEs have CCID20, which has a 20ma trip level, too high to be considered GFCI.the charger may or may not have GFCI (Most are)
After September 1, 2026, under the 2023 NEC, you absolutely will be required to GFCI protect any outside HVAC unit at a dwelling unit on a 50A or smaller breaker, per 210.8(F). All other outdoor equipment at a dwelling unit on circuits in that size range (other than lighting outlets), including EVSEs, is already required to have GFCI protection.You would not put an outside HVAC unit on a GFCI, It is an appliance.
I believe only with a damaged or missing EGC.Is there a rise of shock related deaths on outdoor appliances?
.... Is there a rise of shock related deaths on outdoor appliances? ...
I heard it was a HVAC tech from an improperly wired compressorFrom what I read it seemed the code change was motivated by a single death of a child.
That’s why they started requiring gfi protection on garage door opener receptacles, people were plugging extension cords into those, and running them outside.Electrofelon, When you say "Wall Connector" do you mean the receptacle outlet and the short range cord connected to the charger? Then Yes the connector would need GFCI. Tesla (most) chargers can take a 3/4" fitting from the top, back or bottom, so direct wiring with a pipe through the wall to the garage or Driveway negates the need of the GFCI.
Hillbilly and Jagged Ben, the deaths are sad but it seems like the installation is the problem. It is amazing what that ground wire can do when other stuff goes wrong. Do we need GFCI's because of a small percentage of deaths caused by improper wiring. People will still hang extension cords out the window to run the hedge clippers and get electrocuted, how do we stop that? Is the DYI culture and incorrect Youtube videos the bigger issue? Who is to say.
No, "Tesla Wall Connector" is what Tesla calls its EVSE. The current Tesla Wall Connector (version 3, I believe) supports hard-wiring on a 60A circuit to provide 48A continuous to the EV (if its on-board charger is so rated). And putting it on a 60A circuit means that 210.8(F) would not apply.Electrofelon, When you say "Wall Connector" do you mean the receptacle outlet and the short range cord connected to the charger?
The issue is that the current standards for hardwired electrical equipment do not, in general, address leakage current. The assumption on the part of the standards writers is that the code required EGC takes care of leakage current issues on hard wired equipment.Hillbilly, exactly but there is still stupid and it is still done particularly on older houses so these incidents will still happen. You can't put a code requirement for stupidity. Do you think GFCI's on every thing outside will stop electric deaths? I admit it won't hurt and nuisance tripping will happen but generally a listed appliance will be tested and ground leakage should not be an issue, but we know it be a nightmare for the first few years. The finger pointing between the appliance manufacturers and the breaker manufacturers will be fun and the contractor will be stuck working for free to resolve the problems.
