gadfly56
- New Jersey
- Professional Engineer, Fire & Life Safety
Well I don't know, sounds like the situation stinks pretty good.It's actually "wreaking" havoc. ~ Courtesy of your local Grammar Police.![]()
It's the requirement for AFCI that reeks.It's actually "wreaking" havoc. ~ Courtesy of your local Grammar Police.![]()
Yes, you are correct. I should be more careful.It's actually "wreaking" havoc. ~ Courtesy of your local Grammar Police.![]()
There is an NEC defined "outlet" for every load, exact location of the "outlet" may be up for debate at times though.I understand "outlet" and it may be a loophole, but assume I supply a HVAC condenser wiring straight from a breaker in an outside meter combo (in sight from the unit)... No outlet, no GFCI, correct ??
But outside receptacles and outlets don't require AFCI so the pool heater shouldn't be requiring it.It's the requirement for AFCI that reeks.![]()
