cschmid
- Northern cold country
ok bob stabilize is the wrong term what it is becoming is the aqua stat..it takes the temp via a pipe reading and then it determines the appropiate temp and then turns the boiler on at that temp..it takes the normal 10 to 15 degree temp split on the aqua stat and turns it into what ever temp it determines is mathmaticly correct..the output of the aqua stat still opens at what ever it is set at but when it closes the heat master will not allow the output to trigger the burner until the temp it (heat master) determines is correct temp to fire at..so the heat master is controling (not stabilizing) the water temp..
