stickboy1375
- Litchfield, CT
Now you've stolen my joy/hope.I know a GFCI doesn't need a ground to operate, I just thought it might be sensing an imbalance from the other circuit coming through the bonded EGC/neutrals.
I think along with replacing the GFCI, I will feed the light from the line side of the GFCI like it should have been to start with.
However, if there's a problem somewhere in the other circuit, I don't want to leave it unresolved. Back to the drawing board Monday!:rant:
Best thing to do is take the fixture down and break all the splices, see if the problem still exists, and work your way backwards till you can make the problem exist again, this will put you in the right direction of where to start looking for the problem... don't be surprised to find a buried box somewhere.
