Help with Manual Transfer Switch
I think that diagram doesn't help as what you are discussing appears to me to be to the left of where the diagram starts - you are talking about an arrangement prior to the service entrance. In the diagram above the transfer switch is after the service entrance.
RUWired said:
Perhaps this drawing shows what the op's situation is. In this drawing i show the required grounding conductor between the gen set and the transfer switch.
That drawing helps out a lot, and yes dbuckley, you are correct that other diagram is different than our situation, I didn't look closely enough. Thanks a lot for the help!
