M. D. said:Does this help at all???
Yes that helps, and that is what our guidance advised. Thanks a lot, that picture helps out a lot.
RUWired said:Perhaps this drawing shows what the op's situation is. In this drawing i show the required grounding conductor between the gen set and the transfer switch.
M. D. said:I found this article thought you might want to read it
